'97 auto, ? on replacing tranny fluid + filter. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2004, 10:15 PM   #1 (permalink)
View N4TECguy's Photo Gallery
First off, I wanna know is it actually possible to replace the tranny filter? The last time I heard, those aren't replaceable anymore but my dad says they are. Also how hard is it to change the fluid? Is it even necessary? 143K now, planning to take it way way above 200K.
'03 Camry SE I4 AT - 102K
'02 Camry LE I4 AT - 135K SOLD
'97 Camry LE I4 auto - 188K SOLD
'04 Mazda6s V6 5MT - 65K
N4TECguy is offline   Reply With Quote
Old 06-01-2004, 10:35 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: '97 auto, ? on replacing tranny fluid + filter.
Yes.
You unbolt the tranny pan and you'll see the filter bolted to the tranny.
Changing the fluid is easy. You just unscrew the drain plug, let it drain, reinstall drain plug, and fill it back up through the dipstick.
The above method (drain & fill) only drains out a few quarts though. You'll still have fluid left in the torque converter.
Your other option is to have it flushed. This method pumps in new fluid while the old fluid is pumped out. It replaces all the fluid (tranny & torque converter) with new fluid.
You also might want to do a drain and fill on the differential.
And yes changing the fluid is necessary. I believe the dealership suggests every 30,000 miles.
"Skoolin' the unlearned!"
Old 06-01-2004, 10:42 PM   #3 (permalink)
How much fluid is left in the torque converter and is it really worth it to change it? How much fluid does the tranny hold?
Old 06-01-2004, 10:58 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
A few quarts? It holds quite a bit, but i'm not exactly sure how much it holds.
4 cyl. (5S-FE)
Automatic Transmission, Initial Fill..........2.7 quarts
Automatic Transmission, Total Fill..........5.9 quarts
Differential, Front..........3.4 pints
V6 (1MZ-FE)
Automatic Transmission, Initial Fill..........3.7 quarts
Automatic Transmission, Total Fill..........7.1 quarts
Differential, Front..........1.9 pints
http://amsoil2.cpinternet.com/script...msoiloaf:index
