What should i check next P0500 code
I just finished a tranny swap on a 1998 camry. Before the speedo was working fine, after it will work until the first or second shift and then drop to 0 and throw the code p0500. I swapped the old VSS onto the new(junkyard used) transmission and no change. I checked the fuses under the dash and they were good. Sometimes when I wiggle the wires leading to the vss it will work for a moment but then stop again. I'm thinking it might be the wiring but I have no clue how to test them.
Also whenever I pull the VSS it seems pressurized in the differential, there is a solid "thump" air pressure noise when I pull it out.
Any help would be appreciated, thanks.
