Originally Posted by deejayphilo
Yah its too runny too. It seems like it is mixed with water but where the water came from? I will flush it agsin and refill to see if it can push out from hose going to the radiator...
The transmission fluid is run through a line that passes through the radiator internally to cool the transmission fluid. It's possible there's an internal leak, and coolant is getting into the transmission fluid. Is your coolant level OK?... does it get low and need to be topped off periodically?
