obscure speed sensor tech question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2011, 05:46 AM   #1 (permalink)
View totc's Photo Gallery
4th Generation obscure speed sensor tech question
I need to install my rally odometer in my 1999 V6 Camry.
There are a couple different ways to get a reading
One is a hall effect sensor on a wheel stud. I really don't feel like going through all that trouble of a bracket and having to purchase the sensor itself.
Two is to tap into the vehicles existing speedo cable and run a piggyback line from that to the odometer unit. As I understand it, most modern cars do not have a mechanical linkage to the speedometer any longer, so I believe this option is out.
Third is tapping into the speed sensor on the computer. This was relatively easy on my Subaru. I found the pin out and which wire it was, and I just tapped that wire for the signal. This is the option I want to use.
So my question is this; Where is the computer in the car that handles such chores and does anyone know the connector and wire(s) I would need to tap to hook this up?
Thank you very much.
totc is offline   Reply With Quote
Old 11-21-2011, 07:06 AM   #2 (permalink)
Pvt-Public's Avatar
Gameroom cash: $274350
View Pvt-Public's Photo Gallery
If you PM me your email, I'll send you the wiring portion of the FSM. You should be able to find it from there.
Pvt-Public is offline   Reply With Quote
Old 11-21-2011, 08:35 AM   #3 (permalink)
4th Generation
PM Sent and thanks. Also, do you know if it's a two or three wire harness?
Old 11-21-2011, 09:54 AM   #4 (permalink)
Pvt-Public's Avatar
Not sure my car is 1000 miles away right now or I'd look. Email sent happy hunting.
