Timing problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2011, 10:22 AM   #1 (permalink)
View evoo's Photo Gallery
3rd Generation Timing problem
1997 Camry 2.2 Timing problem after setting # 1 piston up=== and on TDC=== car would not start .When turning over it has a lope to it and a deep sound. Sounds like I missed it, I thought that I had read somewhere that I could be one tooth off.is there any advice on this matter.
evoo is offline   Reply With Quote
Old 11-21-2011, 10:28 AM   #2 (permalink)
View deejayphilo's Photo Gallery
Check your mark if you just did that timing belt then its just the mark...you can google image the timing of 5sfe if thats your engine type....or maybe your firing order from the distributor if you took it out.
deejayphilo is offline   Reply With Quote
Old 11-21-2011, 11:18 AM   #3 (permalink)
2002,5SFE
View houra's Photo Gallery
where is the timing mark ?
houra is offline   Reply With Quote
Old 11-21-2011, 12:45 PM   #4 (permalink)
Thanks for your reply, yes it is a 5sfe, I will check the firing order, but I think that part is good,
Tags
timeing belt, timing
