ABS Works Only Sometimes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2011, 06:13 PM   #1 (permalink)
rty
Gameroom cash: $298766
View rty's Photo Gallery
4th Generation ABS Works Only Sometimes
I've been randomly getting the ABS flashing light on my 97 LE V6. It almost never comes on when I start the car though. Usually after about 5 minutes of driving the ABS light will go on. Sometimes it won't come on at all and I am able to complete my commute without the light going on. Once it does come on it stays on until I shut off the car. It seems to be somewhat random.
I tested the brakes, and sure enough the ABS works properly when the light is off, and doesn't work when the light is on. I also have the traction control and when the ABS fails I also get the light for the traction control, and that seems to behave the exact same way.
I was just wondering if you guys had any ideas as to why the ABS/ traction control system might work properly sometimes, but other times fail?
rty is offline   Reply With Quote
Old 11-21-2011, 11:45 PM   #2 (permalink)
View matt1mzfe's Photo Gallery
If one of the wheel sensors fails - wire broken... then the system turns off (I think) it needs to do that otherwise it would detect one wheel with no speed - ie locked up.
If it is an intermittant problem then that is the likley cause (it is the most common thing on the Holden cars where I was a mechanic)
matt1mzfe is offline   Reply With Quote
Old 11-22-2011, 06:46 PM   #3 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
My Camry had those symptoms with the ABS a while back. Turned out it had a bad wheel speed sensor. Get the error codes read to be sure, though. Could be a lot of things.
BMR is offline   Reply With Quote
Old 11-22-2011, 11:06 PM   #4 (permalink)
Camry Owner
View Aetebet's Photo Gallery
I wish I had ABS
Aetebet is offline   Reply With Quote
