Heating problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2011, 08:14 PM   #1 (permalink)
View yeahitsgottahemi's Photo Gallery
3rd Generation Heating problems
Hey guys,
I have a problem with my Camry...
At idle, i have poor heat but when i drive on the highway or at a constant speed the heat is good.
I recently did the heater core, timing belt, water pump, thermostat and radiator...
I have no clue what to do anymore....
Anyone can help me please???
yeahitsgottahemi is offline   Reply With Quote
Old 11-22-2011, 01:46 AM   #2 (permalink)
Dave's
Gameroom cash: $121550
View Dave's's Photo Gallery
Are you using recirc? How's your blower/fan working? I'm wondering if you're not getting good airflow at idle but on the hiway the outside air is forcing more airflow thru the core.
Dave's is offline   Reply With Quote
Old 11-22-2011, 05:51 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
What does the temp gauge read at idle and on the hwy?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 11-22-2011, 05:39 PM   #4 (permalink)
rusty9's Avatar
Gameroom cash: $440905
View rusty9's Photo Gallery
sounds like you are low on coolant
rusty9 is online now   Reply With Quote
Old 11-22-2011, 08:27 PM   #5 (permalink)
i checked the coolant and it was full in the radiator.
the tempurature is normal (about half way up the gauge)
Old 11-22-2011, 11:47 PM   #6 (permalink)
View White95Cam's Photo Gallery
Originally Posted by yeahitsgottahemi View Post
Hey guys,
Did you "burp" the air out of the system? Did you use a thermostat with a jiggle valve and is it in the correct position?
W95c
White95Cam is offline   Reply With Quote
Old 11-23-2011, 06:09 AM   #7 (permalink)
Sounds like a flow volume problem. How old is the water pump and have you kept up on coolant maintenance?
Old 11-23-2011, 09:27 AM   #8 (permalink)
timing belt and water pump was done in august of this year, new coolant at the same time
Old 11-23-2011, 10:24 AM   #9 (permalink)
Sorry, you did say in the original post that the WP was new. Does this vehicle have a water valve to regulate cabin heat?
Old 11-23-2011, 05:59 PM   #10 (permalink)
Dave's
I wondered about the valve as well but why would it react differently at different speeds?
Old 11-23-2011, 06:07 PM   #11 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
How about a faulty blend door? If you are getting outside air directly in the cabin instead of through the heater core, heat will suck.
Zembonez is offline   Reply With Quote
Old 11-23-2011, 06:22 PM   #12 (permalink)
Well if it's restricted then a higher WP speed will create a higher flow across the valve - in theory, and provide more hot water to the core. Anyway, wouldn't hurt to check if it's opening fully.
Old 12-24-2011, 07:52 AM   #13 (permalink)
View ejrobins's Photo Gallery
I have the exact same problem... New thermostat wth antifreeze and temp gauge right in the middle as well, and control valve moves like it should. I'm thinking flow too, but what would restrict it? I always assumed a waterpump either worked or leaked. Cud the impeller wear out?
ejrobins is offline   Reply With Quote
Old 12-24-2011, 08:14 AM   #14 (permalink)
Usually not (at least not before the shaft seal) if you've kept the coolant in good shape.
The Following User Says Thank You to Stillrunning For This Useful Post:
ejrobins (12-25-2011)
Old 12-24-2011, 08:30 AM   #15 (permalink)
View CarryMeBF's Photo Gallery
Did you install the thermostat correctly (with the little hole at the top; or like the previous thermostat was in there prior)?
2001 Toyota Camry LE V6 with 156k miles
2007 Toyota Sienna LE with 89k miles
CarryMeBF is offline   Reply With Quote
