Headlight upgrade - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2011, 04:27 PM   #1 (permalink)
View marragtop's Photo Gallery
Headlight upgrade
I want to put brighter low beam bulbs in my 96. I don't want the 'blue light' looking ones, and I want to make sure I don't put something in that may overload it from a wiring perspective. I'd appreciate recommendations. Please be somewhat specific in terms of manufacturer and type bulb. In other words I need more than just 'sylvania'
thanks
marragtop is offline   Reply With Quote
Old 11-22-2011, 09:05 PM   #2 (permalink)
Domesticon Prime
Gameroom cash: $206500
View Silent Runner's Photo Gallery
thanks
If your looking for something (a better light bulb) that will make you say: "Gee thats great, thats a whole lot brighter and better", its just does not exist, sorry. Well, actually an HID bulb conversion will make it shine like crazy, but will drive oncoming cars even more crazy. HID, systems briefly demand more power at start-up, but actually draw much less power to operate. (Toyota puts HID lights in its Prius for example) To do this right however, you will have to go big time custom. Search the threads, theres lots of material.
edit: 4900K will give you nice white light.
Domesticon Prime
93' LE V-6, 303K Km., fully optioned including Leather Interior. ES300 rear discs, twin piston front calipers, Depo Chromes with HID projectors, 17" OZ' summer's, 96 corner lights, MAF, timing, exhaust and intake mods, 2001 Toyota/JBL sound, + more and always more coming.
Silent Runner is offline   Reply With Quote
Old 11-22-2011, 11:45 PM   #3 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
If you needed addition light, you can always install white/clear fog lamps in the bumper and aim it low to the road. (>$20 for a kit) I drive home late at night having the two extra driving lights helps a lot.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 11-23-2011, 02:07 AM   #4 (permalink)
Gameroom cash: $254267
View sarsman45's Photo Gallery
You could place 9012 instead of 9006's. The run brighter and keep the same plugs. All you gotta do is cut some of the clips on the 9012 to fit the housing.
http://shnu.us/HIR%20Trimming%20Stock.htm
'02 Toyota Tundra iForce V8 TRD AC THUNDER "FRACKING" GREY METALLIC 97000 miles
sarsman45 is offline   Reply With Quote
Old 11-23-2011, 10:55 AM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
^+1
Old 11-23-2011, 11:20 AM   #6 (permalink)
on full afterburner
Gameroom cash: $1340197
Or you can run 9005 bulbs in place of the 9006's if you're on a budget. Same modification applies.
Old 11-23-2011, 11:57 AM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
I wouldn't recommend using high beam bulbs in place of low beam, because they will burn out really fast (months at most).
if I'm not wrong high beam bulbs are designed for only 300 hours of continuous use at full power (65W), so even when running them at low beam power (55W) they won't last as long as true low beams.
numbers could be wrong, but the difference is there.
Old 11-23-2011, 01:14 PM   #8 (permalink)
View BCRolla's Photo Gallery
In response to "fenixus" the wattage draw is determined by the bulb not by the connector.
If you hook up a 65W bulb to a 55w connector it will still draw 65W. Providing that the wire is not bottle necking the current flow by being too small of gauge, and that the wire thermally(insulation wont melt) can handle the increased current load. It should since its only an increase of 0.83 A from 4.53 A which is about a 18% increase in current at 12V.
I checked though and the wire gauge on my 93 Camry SE V6 is the same for both low and high beam bulbs therefore the low beam can handle a 65 W bulb without issue.
As for service life, that is determined by the bulb manufacturer there is no standard run time for bulbs. It comes down to filament wire gauge and gas composition inside the bulb, check with the bulb manufacturer in order to determine the bulbs average life time.
Just last night I did this mod, for my low-beams and modded the connector rather than the light since I didn't want to repeat the work for the next set of bulbs i put in. There are two plastic ridges down the center of the connector, I shaved them off with a brand new razor blade came off like butter took about 15 mins for both lights.
I'm running PIAA 9005 Extreme White Plus which is a 4000 kelvin bulb, I noticed a significant difference in light. I left the passenger side stock bulb in and replaced the driver side with the PIAA bulb and the light projected easily 40% further than the stock bulb, as well as spreading the light further laterally which aids with peripheral vision at night. It was also very white compared to the yellowish color of the stock bulb.
http://piaa.com/Bulbs/Bulbs-9000.html
The other benefit to running 9005's is that the top of the bulb is clear thereby projecting more light forward, I attribute this to the gain in light projection.
1991 - Corolla Wagon 4A-FE (5spd) (deceased 387k km)
1992 - Corolla Wagon 4A-FE (5spd) (deceased 306k km)
1993 - Camry Sedan 3VZ-FE (5spd) 208k km going strong
1994 - Honda Magna - 77k KM
BCRolla is offline   Reply With Quote
The Following User Says Thank You to BCRolla For This Useful Post:
fenixus (11-23-2011)
Old 11-23-2011, 02:22 PM   #9 (permalink)
抵抗は無駄です
fenixus's Avatar
^ you are right on wattage draw, my bad.
well, I may try using 9011 trimmed as 9006 on my V6. when I get to adding more (HIR) lights, I will get 4x 9011 and trim one pair for low beams and the other for high beams.
the current 9012 (trimmed as 9006) will get moved down to fogs (mine are 9006 compatible).
I am only worried about high beam bulbs longevity when used a lot, that's pretty much all. I wouldn't like to see them burn out after 2 months or something hehe
The "correct application" Toshiba HIR low beams (9012/9006) can do up to 3 years. Philips could probably last longer as they are newer revised design.
Old 11-23-2011, 02:34 PM   #10 (permalink)
IIRC Toshiba doesn't make them anymore and john deere jacked the price up after finding out what car modders were doing. I got a set of Philips off Amazon.
Old 11-23-2011, 05:44 PM   #11 (permalink)
RNMCGUIRE's Avatar
View RNMCGUIRE's Photo Gallery
I recently installed the Sylvania XtraVision bulbs and they're pretty decent for the price. I didn't want to go with the Ultra because they prolly wouldn't even last a year and for $50 I'll pass.
RNMCGUIRE is offline   Reply With Quote
