97 Camry V6 misfiring
Hi,
Had an issue with check engine light coming on and off for a few days and experiencing minor problems, stalling, not starting. The morning I drove it up to the mechanics it started running really rough. The check engine light was apparently a coolant temperature sensor which they replaced at a cost of $150, looked this up and it made sense for what I was experiencing initially with the car when the light was on before it got worse. This didnt get rid of the rough running, seemed to make it slightly better though.
Mechanic has suggested plugs or ignition leads and quoted $400-$500 to replace as spark plugs in a really bad location and will need to take some stuff apart to do it, I looked this up on here and other sites and yeah looks like a real pain to do, tried replacing spark plugs that I could get to this morning, hoping that it was just one of the front ones that had fouled or something. No good. I managed to replace one of the back ones but cant reach the others (dont know how some of the people here have done it!)
In replacing the 1 back spark plug I noticed there was a small amount of oil around the hole and the plug socket was oily also, I believe from reading today that this could possibly cause the wire to fail/short?
The car seems like it's missing and shakes a bit when going slow, when reaches a cruising speed it is not as noticeable. Not having problems starting.
Does this sound like ignition leads/ spark plugs?
I dont want to & cant really afford to pay out $500 for the mechanic to take the inlet manifold etc off and replace sparks/leads and then find out that it's not the cause.
Thanks for any advice
Additional info - the car was recently overfilled with oil, maybe a couple of litres, was drained the next day after only a short drive, thought this may have fouled a plug or perhaps has caused some other damage.
