1995 Camry 2,2 4 cylinder, 199,600 miles
I'll say upfront I am not a mechanic but can say I am decent at figuring things out. I've searched thru the forums but can't seem to find the situation I have:
Having driven the car a few miles and parked it, when I went to start it a few hours later, it would turn over but not start, After several attempts and waiting a few minutes, it fired and ran fine. A couple of days later with no further problems, it wouldn't start again first thing in the morning. Again several attempts and a longer wait, it fired, ran fine.
The problem became more frequent, taking longer each time to start. There didn't seem to a pattern, hot or cold, long or short drive, the problem got worse to the point it finally wouldn't start at all.
I checked the spark at the plugs, no spark. Checked the cylinders, no gas after trying to start. Checked the fuses in the engine compartment, everything looked fine
That's the extent of my skills. After a few weeks, I tried again yesterday, no spark, no fuel at the plugs. Went thru the fuses again under the hood, again everything appeared fine.
Then went to the fuse panel under driver's side dash. Pulled the 7.5 ignition fuse. Forgot to turn off the key, when I put the fuse back in, I could hear a relay in the engine compartment clicking, thought I may have screwed up.
Turned the key, engine fired right up, ran perfectly. Had someone touch the relays when I repeated pulling the 7.5 fuse, verified it was the EFI relay.
This morning, attempted to start the car again, no start, engine turns over. Pulled the 7.5 fuse again, hear the clicking, engine fires right up.
Any suggestions? Can't afford a mechanic to diagnose what could be any number of problems.
At least need to keep it running long enough to use up the full tank of gas! LOL
