help! idle problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-23-2011, 10:31 AM   #1 (permalink)
Gameroom cash: $108813
View Slaz's92Camry's Photo Gallery
Japan help! idle problem
ok so here it is, when i start my car (cold start) rpms go pretty high around 2k then drop at a normal rate, once i take the car out and drive it for about 5 to 10 min. and put the car in park of nuetral and it shakes/vibrates and the exhaust putters (in video) the car also seems to be running rich (aside from the loud lifters) and has an exhaust smell from the engine bay but all exhaust gaskets r new, maybe egr issue? anyways i would apreciate any help with diagnosis. video link to youtube....
I have checked the vacuum pressure and it was good, did a smoke test and no leaks were found that i saw, plugs and wires are new.
Thanx you very much
Slaz
Slaz's92Camry is offline   Reply With Quote
Old 11-23-2011, 12:16 PM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Test hot resistance of ECT (engine coolant temperature) sensor. Not the gauge switch or the cooling fan switch. If it's faulty the ECU still thinks the engine is cold.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 11-23-2011, 01:34 PM   #3 (permalink)
Hoosier Daddy
View NapalmFTW's Photo Gallery
exhaust smell in the engine bay could be a broken flex pipe.
Mostly blue 1994 Toyota Camry LE. 5SFE ftw.
NapalmFTW is offline   Reply With Quote
Old 12-05-2011, 06:54 PM   #4 (permalink)
update.... CEL came on while at red light(and idling like crap) then went away after a min r so of driving.... never happened again any ideas? oh and i checked the ECT and it is with-in specs.
