dashboard clock dim + New dome light bulb doesn't work + power locks stopped working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-23-2011, 06:44 PM   #1 (permalink)
View 200k_or_bust's Photo Gallery
Anyone know what is going on here?
I tried to replace what I assumed was a blown out dome light. That didn't fix it. Then I noticed the dashboard clock was very dim. Next thing I knew, when I got out of the car, the power door locks had stopped working (if the key was out of the ignition). Since you can't power lock the doors shut while the key is in, I had to remove the key, and manually lock the doors.
Anyone know what is going on? Thanks!
200k_or_bust is offline   Reply With Quote
Old 11-23-2011, 09:27 PM   #2 (permalink)
Hoosier Daddy
View NapalmFTW's Photo Gallery
Can you turn the lights on without the ignition?
Check the Dome 20A fuse under the hood. It's a micro fuse. It controls more than the dome light.
Mostly blue 1994 Toyota Camry LE. 5SFE ftw.
NapalmFTW is offline   Reply With Quote
Old 11-23-2011, 09:28 PM   #3 (permalink)
Turn which lights on? The dome light doesn't go on either way. Otherwise, all lights seem to be working.
Old 11-23-2011, 09:29 PM   #4 (permalink)
Hoosier Daddy
sorry, headlights etc. I blew the Dome fuse on my Gen 3 94 Camry and that fuse controls the radio, interior and exterior lights when the ignition isn't on.
I'd check the fuses under the hood and in the dash.
Old 11-23-2011, 11:04 PM   #5 (permalink)
I'll take a look at both fuse boxes, and see if any individual ones are broken. I hope I can see easily, otherwise, it will be a pain to remove and inspect every single fuse.
Old 11-24-2011, 12:57 AM   #6 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
What car do you have? Do you have an external amplifier under the passenger seat?
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
Old 11-24-2011, 06:38 AM   #7 (permalink)
No, just a stock 1999 Camry.
PS: 71 Corolla! Very cool! You must get a lot of raised eyebrows while driving
Old 11-24-2011, 03:17 PM   #8 (permalink)
Update: The owner's manual showed that the Dome fuse and controls the clock and the opweer doors. I changed the busted 7.5A fuse with a 10A spare. Can I get away with this, or do I need to buy a 7.5A one to be safe?
Old 11-24-2011, 11:17 PM   #9 (permalink)
View 1996camry's Photo Gallery
go with 7.5A with the original fuse that came w/ your car. if you don't have 7.5A, you can fuse less than 7.5A. reason... this will protect your car... higher fuse, risk damage before the fuse blown.
buy 7.5A and replace ASAP.
1996camry is offline   Reply With Quote
Old 11-24-2011, 11:21 PM   #10 (permalink)
71Corolla's Avatar
Agreed about putting in the proper fuse. Never, ever put a higher rated fuse in, that is how you burn out things, or even start an electrical fire. I asked about the external amp because of what happened to me.
Old 11-25-2011, 09:24 PM   #11 (permalink)
I bought a 5 pack of 7.5A's and popped it in. Felt nice to get under the hood. Even for a little bit. To be honest, not sure I was up for more. I am glad to have my dome light back!
