problem starting only after every gas refill
I own a camry 2001 2.2 liter engine which I'm gonna marry someday.
The only recent problem I've been experiencing ( started a month ago) is the hard start only after every gas refill. No matter how much gas I put in, I still get the same result . It's like not enough fuel/air is going into the engine etc. It will crank, starts for a millisecond then rpm dies until engine is off. But after the engine turns on, it runs normal...like brand new. And never had any problems until I put gas.
NOTE:
1. I live in Calgary, Canada and Ive been here for 3 years and I only purchased my camry 3 months ago. I thought it might be just the temperature (winter ) that causes the problem which maybe from my gas tank, air pressure mixture, or the gas that I am using etc. when its cold. But no one seems to be experiencing the same problem that I have.
2. Engine light is not on. There are no other indications/symptoms of engine error aside from the said problem.
3. It's runs excellent, no problems at all. Runs like Bnew in between gas refills.
4. recent oil change (mobil 5w-30), mobil atf, tranny and oil filter change.
what could have possibly gone wrong?
Please help.
