electircal problem after replacing thermostat - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2011, 02:45 PM   #1 (permalink)
View wjce's Photo Gallery
USA electircal problem after replacing thermostat
Help!. I attempted what appears to be a simple repair. My 2000 Solara v-6 had the check engine light come on. I took it to Advance Auto and they told me that the thermostat needed to be replaced. So today, I replaced the thermostat and thought that I hooked everything back up correctly.
When we put the key in the ignition, the door open bell rang (the door was open). We tried to start it, but it made a noise like it could hardly crank and then we heard another louder click/pop. At that point, the door bell stopped working.
I moved and remounted one of the ground wires and the bell came back on. So we tried to start again, but nothing. Not even a click. So I thought that I had a short in the battery. I got out my ohms meter and the battery registered 12 v. When we tried to start the car again, nothing and the battery voltage didn't flucuate.
So, I'm assuming that I either blew a fuse or shorted out something. I looked at the fuse pannel but didn't see any fused that looked blown, but I didn't pull them out.
Additionally, we bought this car used, and it didn't have the owners manual, so I'm not sure what fuses I should even be looking at.
Any ideas on what it could be or what to do next.
Thanks so much for your help.
Clark
wjce is offline   Reply With Quote
Old 11-24-2011, 08:19 PM   #2 (permalink)
View Pauloil's Photo Gallery
so did you see the temp sensor near there and get its wires wet?. further, thermostats don't usually set a code, the car is cold too long and the gauge goes up too slow etc., but not a code. what was the code?
Pauloil is offline   Reply With Quote
Old 11-24-2011, 10:42 PM   #3 (permalink)
solved the problem
Boy do I feel stupid. I went back out later and discovered the problem was the we didn't tighten the battery terminal tight enough. Once we did this, everything was fine.
Old 11-25-2011, 08:59 AM   #4 (permalink)
if and when the code comes back,post it here. stats don't usually set CEL. i usually leave the electrical sys. alone when doing a stat. unless the temp. sensor needs changing
Old 11-25-2011, 10:20 AM   #5 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
Don't feel bad. We've all pulled a similar stunt at one time or another. Glad it's fixed. Must admit I have never heard of anybody ever replacing a thermostat based on a code. Odd.
Zembonez is offline   Reply With Quote
Old 11-25-2011, 10:37 AM   #6 (permalink)
2001 Camry XLE 1MZ-FE
View ajkalian's Photo Gallery
I just got a P0128 on my way home from Turkey Day festivities
That might be what Autozone found when they scanned OP's car.
More info here:
http://repairpal.com/check-engine-li...e-of-p0128-362
And here:
http://www.obd-codes.com/p0128
2001 Camry XLE, 6cyl, 1MZ-FE, 91,000 miles.
ajkalian is offline   Reply With Quote
Old 11-26-2011, 10:28 PM   #7 (permalink)
More info here:
And here:
my bet would be on the ECT. esp since you just put new thermo in. you could check to see how its resistance varies wrt temp., or just replace it, being sure to reset adaptives by taking neg cable off 15 min. or by touching brake when cable is off.
this might be it. either reuse old gasket ring or get new
http://www.stockwiseauto.com/product...lara/Year/2000
Old 11-26-2011, 10:41 PM   #8 (permalink)
here it is on amazon
Amazon Amazon
or you could take it out and go show to the parts guy at your local dealer
