Originally Posted by jlawson435
The EATC is OK.
Do you mean this EATC:
http://www.aircondition.com/dsmobileac/eatc.html
How do you know it's OK? Is there a manual setting on the ATC system?
Can I go out to the blower motor and tap into the wires and run a new resistant switch into car and bypass the blower motor control module.
I don't know that I'd "tap" into the wires for fear of back feeding electrical power to EATC. You might be better to just cut the wires to the motor and splice in by-pass power through a switch and an inline fuse to the motor then to ground. The problem you'll have is picking a motor speed as the existing system will have motor speed control resisters somewhere. Is the motor speed set by the ATC system as well?
How many wires does the motor have going to it?
