Steam from overflow but not overheating - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2011, 01:00 PM   #1 (permalink)
View Strapwrenchgirl's Photo Gallery
Exclamation Steam from overflow but not overheating
After driving my 1998 Camry for short distances, I notice steam coming from the overflow. One of the fans isn't running (the one closest to the overflow). The thermostat and radiator were replaced within the last year. The Engine is not overheating. I have not detected any leaks. Any ideas as to how I might repair this?
Strapwrenchgirl is offline   Reply With Quote
Old 11-26-2011, 01:14 PM   #2 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
The fan that isn't running is the AC fan so only runs if the AC compressor is also running.
The steam might be caused by an improper mixture of antifreeze -- too much water. Get an antifreeze tester and check the mixture.
Chris Crash is offline   Reply With Quote
Old 11-26-2011, 04:31 PM   #3 (permalink)
Exclamation
We flushed the radiator fluid and replaced it with new 50/50 mix. The same thing is still happening. It isn't due to having too much water. Any other ideas?
Old 11-26-2011, 05:59 PM   #4 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Try a new genuine Toyota radiator cap and go from there.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
Old 11-26-2011, 06:12 PM   #5 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
^^^ This.
Zembonez is offline   Reply With Quote
Old 11-26-2011, 07:58 PM   #6 (permalink)
The radiator and it's cap are less than a year old. Both are genuine Toyota parts.
Old 11-26-2011, 08:17 PM   #7 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Well... if you are getting steam past a functioning cap, you are indeed either getting too hot or possibly have a failed headgasket that is allowing compression into the cooling system.
It is a possibility that the cap has failed. I would try a new one.
Tags
coolant, overheating, radiator, steam, thermostat
