95 Camry 4cyl engine mount opinion wanted
Hi all,
95 Camry wagon 4 cyl Auto. 184,000 mi
Had the usual shaking in idle under load and in neutral. Replaced the dog bone about a year ago, which helped a bit. Vibration got worse recently so I just replaced the front and transmission engine mounts which has helped a lot. There is still a little low vibration. I was wondering if it could be that the dog bone got damaged after over a year of driving with it being the only good mount, and needs to be replaced, or if I need to replace the rear mount. From what I've heard, the rear mount does not go bad very often, and if it does, it really only causes a thunk when changing gears (I've got no thunk), but does not affect the vibration much. I'd rather not spend the $ and the time replacing the rear (as it is more expensive, and more difficult) just to find out it was the dog bone. So, if anyone has and opinion, I'd really appreciate it. Thanks.
