when does lower rad hose get HOT? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2011, 09:58 PM   #1 (permalink)
View Pauloil's Photo Gallery
01 4 cylin Camry put in new stat and bled system twice by running to hot twice with rad cap off. Did see some bubbles. Never did feel lower hose get hot, so when does it warm up?
Pauloil is offline   Reply With Quote
Old 11-28-2011, 11:13 PM   #2 (permalink)
Earning Stripes
TRD95's Avatar
View TRD95's Photo Gallery
You need to allow the thermostat to open up once it reaches temperature. Then you'll feel the flow change temperature. Make sure your thermostat isn't stuck in the closed position.
Killed in action - 11/22/2011
Final Score - 355,202 Miles
Dynomax Exhaust | DEPO Clears | 8000k HID Kit | PIAA Fogs | Weapon R Intake | Optima Red Top | Brembo Front Rotors | TRD Grille | Potenza G19s | Koyo Radiator | Perma-Cool ATF Cooler | JVC Ipod & Bluetooth On Board |
TRD95 is offline   Reply With Quote
Old 11-29-2011, 08:34 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
In cooler climate it can take a long while. But if the upper hose is getting warm at the radiator end then the coolant is probably flowing fine (not a stuck thermostat).
However, a cheap aftermarket thermostat without a jiggle valve can cause air to be trapped and create some problems too. IMO I'd use only OEM or a Stant OE-Style stat with a jiggle valve.
