Opps! 1mz-fe oil filter on 5s-fe. Should I be worried? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2011, 08:18 AM   #1 (permalink)
tef
View tef's Photo Gallery
I changed my oil yesterday on my 2000 Camry with a 5s-fe engine. As I was turning into my driveway I suddenly realized I had used the wrong oil filter. I put a 1mz-fe filter on. Should I be worried. I've already driven 100 miles. The filter is not leaking. I've compared the two filters and the 1mz-fe filter has a slightly larger diameter gasket. But like I said the filter is not leaking. Anything else I should be concerned about? Thanks
tef is online now   Reply With Quote
Old 11-29-2011, 08:39 AM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
No worries.
I do this to reduce types of filters I keep on hand.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 11-29-2011, 09:49 AM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
nah, it will work fine. as you noticed the only real difference is the diameter of gasket at base, other specs are very similar (oil flow rate, bypass valve pressure, etc.)
Old 11-29-2011, 08:28 PM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
No worries. The older 3SFE had an oil filter similar to the standard V6 sized one. Others have used a larger -YZZD3 size filter for the V6. The only disadvantage is longer initial fill time or if the 5SFE has a drain-back problem (even with OEM filters overnight). Otherwise Motorcraft FL400S oil filter should work fine for both.
