Thanks for the help BigBird & Chris Crash. The problem i see right now is arms on the outter door handle they are broken,(cheap plastic) so lifting the outter door handle wouldn't open the door. What I don't understand is why wouldn't the door handle on the inside open the door? As I stated before pulling the rods from the inside to open the door didn't get the job done either. I had to cut a hole in my door panel & reach my arm all the way to the lock mechanism itself to get the door open. I then took door panel off (garbage can) and unhooked the rods,unbolted lock actuator,unbolted outter door handle and took them both out. I found the broken pieces in the bottom of my door. I hope its just the outter door handle that needs to be replaced and nothing more. Im off to the junkyard tomorrow for an outter door handle and a new door panel. I will post the final results when Im done. Mike
