I hadn't had the chance to test the coil as its under the distributor and being the only
car I have wanted to look into all possible scenarios before anything. This way
I could still travel to get parts.. I may have made matters worse, then be stuck.
I will be testing the above mentioned in the morning as a friend is going to drive
me to the scrap yard to see if I can get the whole assembly. I have had good luck with
parts from the wreckers so far.
The price of the coil and cap were quoted from UAP NAPA here in Toronto, I was surprised
myself to hear that price. But on the other hand kind of used to high prices here.
The logic behind the the sensor on the rotor being the issue appears to be sound
given that both the injector pulse is missing as well as no spark. The guy
who tested the injector line knows his toyota's pretty well and owns a
mechanic shop and has always steered me in the right direction... With that in mind im hopeful
that hes right.
I drove across the city today just to run the problem past him to get his thoughts
on it, and sure enough the car would not start when I went to leave. He had
a set of lights that clip onto the injector harness and he tested it on the spot
for me.
He said that the only thing he could think of other than the sensor on the
rotor assembly would be the ECU
and the odds would say that the ECU would not be the issue, at least I hope not... $$$...
A buddy of mine is coming down in the morning, so I will take it all apart
before we head off to the wreckers and inspect all the parts first. I also
want to take the original parts just to make sure I get the right ones.
Im not too concerned about getting used parts at this point, I think its
best to get it running and get rid of it, and start looking for a truck.
I may only spend 50-60$ for all the parts, so even if I get something that
is not needed I wont be at a huge loss.
If I change the whole assembly including the coil, chances are I should be good.
From all the feedback ive got on the issue, I think Ive got the
bases covered at this point.
I was lucky enough to have it act up when at the shop, as I would have never thought
of testing the injector pulse, so I think today put me one step ahead in
figuring this out.
I have a DMM and the Hanes manual for this car, so will test both the old and new parts to see whats what.
Im also going to grab the temp sensor while I am there, and swap that out.
Hopefully at this time tomorrow I will be posting here with good news and what the root of the issue was in the first place.
Fingers crossed
