Akebono ProAct ceramic pads. Akebono is an OEM brand. Rotors should last about 200K miles with these ceramic pads.
You can and should resurface the rotors if the old pads are not ProAct. Next time if you need new rotors ~$20
Centric C-Tek should do fine, or their ~$40
Premium rotors with powder coated hubs if you have rust problems in the region.
I'd also flush the brake fluid with a low moisture activity fluid like
Castrol GT LMA or
Valvoline Synthetic.
Check the wear patterns and the anchor pins. You should be able to move them very easy with 2-finger pressure.
Originally Posted by dbbd022
Does anybody know if the original brakes were semi-metallic or ceramic? I'm planning on just turning the rotors if I can get away with it. They were replaced at the last brake job.
Also, I was wondering if anybody had any recommendations on pads and rotors (worst case scenario).
Thanks
