Can the radiator be repaired?
Hi all.
Does anyone know if it's possible to replace just the plastic tanks on these radiators in the 4th generation Camry?
Yesterday after a 20 minute drive, I could smell antifreeze when I exited the vehicle. After opening the hood to inspect, I noticed coolant is just starting to weep along the top of the radiator at the junction where the plastic tank joins the aluminum. It seems the seal is beginning to fail at that junction.
A few months ago when I did the timing belt/oil seals/water pump replacement, I had noticed that the plastic tank along the top of my radiator looked brittle with some cracking anyway. So I kinda knew that the time was near for either a possible radiator replacement or repairs.
It has been my experience on other cars that I've owned that aftermarket radiators are never quite as good as what the factory put in. Generally speaking, the design is different where the drain plug is eliminated or the inlets for the transmission cooler lines are mismatched, etc.
If it's not possible to repair, anyone recommend a particullar brand or parts house?
Any response is appreciated. Thanks.
Hank, Northern Illinois
1998 Toyota Camry 2.2l 4Cyl / AT
160k miles
