Anybody just replace the Flex-pipe section or whole pipe? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2011, 11:57 AM   #1 (permalink)
Gameroom cash: $302547
View ricamryman's Photo Gallery
3rd Generation Anybody just replace the Flex-pipe section or whole pipe?
As of Monday I have noticed that exhaust leak buzzing noise comming from under the front of the car upon pressing the gas pedal. I'm suspecting that the front flex pipe section has developed a leak since the front pipe section is original on my 1993 Camry LE 3VZFE V6 with 146K miles. Should I replace the whole front pipe section with a new bolt in unit or can just the flex pipe section be fixed? .........
ricamryman is offline   Reply With Quote
Old 11-30-2011, 01:39 PM   #2 (permalink)
Gameroom cash: $303755
Usually a muffler shop can cut out the old section of the flex pipe and weld in a new one. Dealers usually won't do this; they want you to buy the whole pipe section. A muffler shop will charge about $150 for this repair.
Mike
Old 11-30-2011, 02:24 PM   #3 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
The header/flex pipe can be had for $140 or less new, $10 for gaskets and you'll have a new pipe for the price of a repair. The only issue you might have is getting the bolts off, otherwise the job is actually quite easy.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
Old 11-30-2011, 08:42 PM   #4 (permalink)
RNMCGUIRE's Avatar
View RNMCGUIRE's Photo Gallery
I just had the flex pipe replaced on my 95 Camry a couple months ago at a muffler shop. It cost me right around $100
RNMCGUIRE is offline   Reply With Quote
Old 11-30-2011, 11:02 PM   #5 (permalink)
Gameroom cash: $122650
View 93cr250's Photo Gallery
got my complete flex pipe on ebay for $60
93cr250 is offline   Reply With Quote
Old 12-01-2011, 10:30 AM   #6 (permalink)
View gyjoe's Photo Gallery
I replaced the entire flex pipe/catalytic converter with a Bosal from Rock Auto about a year ago. At $160 it wasn't much more than having the old one welded at a shop.
1998 Camry LE 4 cyl
gyjoe is offline   Reply With Quote
Old 12-01-2011, 11:48 AM   #7 (permalink)
View 99Camry99's Photo Gallery
4th Generation
Mike
^ What he said...
99 Camry LE, Pioneer HU, Sirius, Boston Speakers, 2 12's, Tinted, CAI, K&N, Brembo Cross-Drilled, UD Pulley, Blue LED Underbody, Blue Wheel Well LED's, Blue, White, Amber LED Strobes, Corner Strobes, Autometer Gauges, Optima Yellow Top, “Big 3”, 1200w Inverter, Fog Machine & More... Ask
99Camry99 is offline   Reply With Quote
Old 12-01-2011, 11:58 AM   #8 (permalink)
3rd Generation
You guys are gonna laugh at this one! Today I took my Camry to the neighborhood Firestone to have my Firestone WinterForce Snow tires mounted on which I do every Dec 1st. By the way the Camry is an absolute tank in the snow with these tires mounted for the winter months! Camry is better than my F-150 4x4 in the snow with these tires! While on the lift I have them confirm that my Flex-pipe is Fubar! Which it was just like I suspected! For giggles I have them price up the front pipe replacement. See below
Front Exhaust Pipe $494.08
Gasket (2) @ $ 6.99
Gasket (1) @ $7.99
Remove & replace pipe $89.10
Tax @ 6.25% $32.58
Shop Supplies $ 5.35
Total $ 643.08................ Yeah Right!
It gets better, after paying just $43.00 for the snowtire swap including mouting, balancing, & my free alignment for life which I have on both of my vehicles, I go home & order the front complete flex pipe section from E-bay which includes all gaskets + free shipping to my door for $104.95! My local independent Mechanic will probably just charge me maybe 1.5 hours to install! I just have to find the six mounting bolts now!
Old 12-01-2011, 12:31 PM   #9 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
I would just replace the flex pipe only, part & labor at any muffler shop should not be higher than $150 for that (with 1yr warranty).
Old 12-01-2011, 12:39 PM   #10 (permalink)
3rd Generation
Personally I would rather have a new front pipe with the flex included!....
Old 12-01-2011, 12:53 PM   #11 (permalink)
View tbalon's Photo Gallery
Had this done on my 92 4cyl about 5 yrs ago for about $85 at a local muffler shop... If you go this route, get several estimates and make sure they have the correct part as you don't want to put a smaller more restrictive pipe on as they were going to do with me but I stopped them when I noticed it and had them put on a larger one.
tbalon is offline   Reply With Quote
Old 12-01-2011, 04:08 PM   #12 (permalink)
3rd Generation
I odered one today on e bay for my 1993 v6! Its the right pipe!
Old 12-01-2011, 07:27 PM   #13 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
autozone sells just the flex section that is the perfect diameter for about $20. cut out the old and allow for some overlap, slide new flex section into place and use 2 exhaust pipe clamps to hold in place.
Old 12-01-2011, 11:10 PM   #14 (permalink)
3rd Generation
I'd rather just install the complete front pipe that I ordered with the flex pipe built in. I want a durable repair that I don't have to worry about for another 100K miles.....
Old 12-02-2011, 12:11 AM   #15 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
It would also be a good idea to have your mechanic check the engine mounts.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
