Sudden, massive oil leak. (pics) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2011, 01:50 PM   #1 (permalink)
View IcantDo55's Photo Gallery
1997 Camry 2.2 Auto 230K
So after some searching, it looks like something in my oil pump has gone bad. Looks like its time to do a timing belt while I'm in there too. Judging by the photo and the knowledge that it only leaks when running and when running its a steady stream of oil, what do you think the failure is? Do I need to replace the complete oil pump or just some o-ring I have read about?
What parts would you buy?
Thanks!
IcantDo55 is offline   Reply With Quote
Old 11-30-2011, 01:57 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Either the oil pump o-ring to the pump housing, or the pump shaft seal. See:
Fixing oil leaks: camshaft, crankshaft and oil pump seals
You might want to reseal the oil pan too.
Do a complete job including parts like:
GATES K030295 Micro-V AT Power Steering Belt $5.14
GATES K050435 Micro-V AT Alt/AC Belt $14.10
FEL-PRO TCS45920 Crankshaft Front Seal Set $5.10
FEL-PRO TCS45641 Camshaft Front Seal $3.66
NATIONAL 221820 Polyacrylate Oil Pump Shaft Seal $2.86
GATES TCK199 (1 Belt, 1 Tensioner, 1 Idler) Timing Belt Component Kit
$52.89
STANT 48278 180° w/Jiggle Pin OE Type Thermostat $10.94
AISIN (OEM) WPT010A Water pump w/o housing $30.79
FEL-PRO VS50304R1 Valve Cover Gasket Set w/Spark plug tube seals
$18.26
Subtotal $143.74
Old 11-30-2011, 05:54 PM   #3 (permalink)
View 1996camry's Photo Gallery
your oil pump seal is the problem...if the pump when bad, your car will have engine problem.
1996camry is offline   Reply With Quote
Old 12-01-2011, 08:41 AM   #4 (permalink)
View jandrews's Photo Gallery
4th Generation
Im having the same issue also. My concern is that I just had my timing and water pump changed a few months ago. Last week I replaced my serpentine belt due to my compressor locking up. I was wondering if they should have changed those seals when they replaced the timing belt and water pump. i really do not want to go up in there my self.
jandrews is offline   Reply With Quote
Old 12-01-2011, 01:33 PM   #5 (permalink)
View tbalon's Photo Gallery
The oil pump seals are not usually part of a timing belt service unless specifically requested.
As for the OP with 240K mi. I would second the suggestion to do a very thorough job and have all the seals replaced including the oil pump shaft seal and housing gasket. The housing gasket is usually the one that causes this type of sudden large oil leak. You must be very careful with a leak that bad. as you will run out or oil very quickly and you could ruin your engine. Keep a close eye on your oil level if you don't get it fixed right away!
tbalon is offline   Reply With Quote
