Quick repair questions on replacing front knuckles/spindle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2011, 02:09 AM   #1 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $589157
iTrader Score: 7 reviews
View xpeed's Photo Gallery
So I've noticed that my front, driver side knuckle/spindle needs to be replaced. The holes for the bolts are worn and possibly won't last me much longer. This is one possibility that my steering tends to "correct itself" while I'm taking right turns or while driving around a right bend on the streets.
So my question is, if I'm going to replace my knuckle, I might as well go all out and replace the tie rods, lower control arm, bushings, as well? Should I also replace the one on the passenger side as well? Also, another problem, I can't find any online stores that sells them. Wonder why.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 12-02-2011, 03:01 AM   #2 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Probably because you rarely hear steering knuckles needing replacement.
Are you sure it's not the control arm, or ball joints, tie rods?
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 12-02-2011, 03:13 AM   #3 (permalink)
TN の がしょう
xpeed's Avatar
I'm pretty sure it's the knuckles as that's where the brakes/wheel spindles are connected to right? I only realized how bad it looked when I was replacing the wheel studs. Looked pretty bad, I'm guessing the previous owners went serious off-roading through parking lots and roads many times.
Oh I don't know, I'm going to get a second professional opinion from my mechanic and see what he thinks. If that's that case, then I guess I would have to hold off on getting a custom exhaust system and sports cats installed next year after I get my tax returns.
Old 12-02-2011, 03:18 AM   #4 (permalink)
Avy
That is the steering knuckle. Are you talking about the axle hub/bearing?
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 12-02-2011, 10:45 AM   #5 (permalink)
TN の がしょう
xpeed's Avatar
It's the steering knuckle then. I was hoping there would be a wholesale online store that would sell it cheaper than the dealers....guess I have to trust my mechanic that he'll find one cheaper than the dealers and do a good job replacing it for me.
Old 12-02-2011, 01:37 PM   #6 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
That's something that would be good to get from a boneyard. Rarely need replacing, so they oughta have a truckload of them.
BMR is offline   Reply With Quote
