hey guys i just swaped the bulbs in my speedometer with 5smleds and it was fine for like 10 mins but now its making the the bulb holder hot
and burning smell can be noticed
it was looking great but what cud be the problem?
There's a good chance the LED's are being overdriven. Do the LED's themselves get warm or hot? If one of them is flickering, that can indicate too much current. It will likely fail and take out the remaining LED's.
What color are they? It can easily be fixed with a resistor.
ebay LEDs are cheaply made. I'd rather buy them off from superbrightleds.com. They're of higher quality and should not have any problems with overheating issues. My guess is that the LED doesn't match up correctly with the voltage changes as well as a good quality LED bulb does. The solenoids are probably poorly done, that's why it's overheating. This is actually a first I've heard LEDs overheating. It should never happen since your fuses will take the load, not the other way around.
Color doesn't matter, nor do you need resistors in the gauge clusters since the 74 and 194 bulbs have similar voltage range as regular bulbs does, if not, should use less voltage. Buy them from superbrightleds.com and see if you still have any problems then.
Can you take a picture of the bulb and post it here so that we can help you out a bit more?
If the LED's are being overdriven and getting hot, a resistor will reduce the current and keep the LED's from overheating.
Manufactures of cheap plug and play bulbs tend to run them at a current higher than the LED's recommended rating to produce more light. Another possibility is that the manufacturer designed the bulb to work correctly with a 12V source, when in reality a running car can have anywhere from 13 to 14V or more. As a result, they get hot and die.
Knowing the color can help in determining which resistor is necessary since red, yellow and orange LED's usually have a 2 to 2.6 forward voltage drop. Blue, green and white are usually between 3 and 4V.
But I agree, the easiest solution is just buying a higher quality replacement bulb.
I started by buying cheap china LED's from eBay, like you. And then a bunch of them did what you describe, then went out.
I emailed the people (and also checked the resistors they'd used.)... they are only designed for pretty much 12 volts. As Monoxide said, cars put out 13-14 volts when running.
Me personally, I bought a 100 pack of bare LED's and resistors, and used the bases from the china LEDs to make my own.
However, I am going to ask my own question here. I've built like 6 different bulbs for the 194 behind the fuel gauge, and that thing continually blinks, and eventually goes out. I've even built them so that they would be good for around 16 volts (of course at the cost of brightness) and it still does it. I've built LED strips for the footwells, I did the AUTO button in the window switch, the cig lighter ring - all the crap that they don't "make" a bulb for, and had NO problems. But that fuel gauge bulb has been giving me hell.
82 Toyota Pickup, 22r, 5spd 4wd, Detroit locker, Warn 8274
1998 Toyota Camry - 5S-FE, Auto - 205k
82 Toyota pickup - 20r, 5spd, 4wd - SOLD
A good alternative to resistors for LED voltage control
Hello. I read that there was a concern about voltage control for the LEDs being installed. Some of the posts mentioned using resistors to limit voltage. That can work, but it also has limitations that can be overcome by use of a voltage limiting device. There are low-cost voltage regulators available from electronics shops.
Some of the regulators have the output set by additional circuitry, but some of them are preset for a particular voltage you can specify when you purchase them. You may want to consider the use of a one of those voltage regulator circuits between the supply (output by the alternator and battery) and the bulbs you are installing.
One of the advantages of using a regulator is that the voltage it passes to the LED will be the same, regardless of the forward voltage drop mentioned by Monoxide MS. One of the consequences is that you can change the color of the LED without having to change the rest of the circuit, in case you decide change the color.
is it because of 5 led bulb or any other reason?
Is this thing even design to be use inside the cluster? 5 led that's a lot.
OK, never mind just found it. Assuming that this is 3020 series then it only 1.2Watts. So it shouldn't be that hot compare to original bulb which is about 3 or so.
Did you put 1 resistor per 1 LED in series? If you use more than 1 LED then you'll also need to put resistor in parallel as well. What I'd do is increase your dimmer to the max and then take the reading. Do the EI formula for series resistor and that will be the fix Voltage for LED. You should try Voltage variable LED. It can change color when you change the dimmer.
The dimming function reduces voltage to the lighting circuit.
|The LED assemblies (that is what I am calling your bulbs) need to have proper way to limit the current that the LED will take, too much and the LED heats up and burns out.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
