Camry Fuel Pump/ Relay?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-04-2011, 06:15 PM   #1 (permalink)
View payne2006's Photo Gallery
It all started when I ran out of gas in my 93 camry (2.2). After filling with gas it would start but then die as soon as I would try to drive. Now it will not start at all. I have put nearly 5 gallons of gas in the car and replaced the fuel filter. This seemed to make no difference. After searching the forums I decided to try and run a jumper from my Fp to B+ to see if my fuel pump would turn on. With ignition on nothing but if i run a jumper where efi main relay is to connect 2 and 4 (the pins that are only supposed to be continuous when the car is turning over my fuel turns on and stays on with the ignition. What does this mean. Thanks in advance for any help.
payne2006 is offline   Reply With Quote
