98 rear mount install
98 camry V4, auto. I have been searching for a while on a diy to replace the rear mount, and i haven't found anything really to walk me through it. I was able to replace the strut and the front mount with no problem, but the back i'm sure how to unbolt the top nut on the mount the space is very limited where a socket can't be used. which is the best place to unbolt? under the car? passenger side wheel or from the top?
I know that the rear mount is connected to the bracket that holds the passenger axle, do i have to take off the axle?
I thought about taking off the axle and the bracket that is mounted to the engine so i can get both the mount and bracket out together, but that seems like a lot of work. is there a more simple way?
anyone that has replace the rear, if you can help me out, i would very appreciate it.
thanks again in advance.
