99 Camry overheats after heater core replacement
All-
The heater core on my 99 camry was leaking, so I ordered a new one from Rock Auto.
I installed it, but when I turned on the car and turned on the heater to check for leaks, the car started to overheat. The core didn't get hot, and the air coming out of the blowers was cool, so I don't think the coolant was circulating through the core.
I thought maybe I had the inlet and outlet hoses mixed up (does it even matter?), so I reversed them, but still it over heated.
I disconnected the hoses at the firewall and installed a bypass pipe, so the inlet hose is connected to the outlet hose, bypassing the core.
The car didn't overheat this way.
What do you guys make of this?
Is my new core clogged?
