Toyota Coolant questions. Change to Toyota pink or stick with green? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2011, 12:39 AM   #1 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $589157
iTrader Score: 7 reviews
View xpeed's Photo Gallery
I was wondering if flushing out my antifreeze coolant from the green to pink will do anything to the engine. I know that Toyota pink coolants are for newer cars, but will it damage the engine for older cars like my Gen 4? Are there any restrictions based on that? I've searched and found nothing that answered my question. Thanks all.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 12-08-2011, 12:45 AM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Better to stick with red since it costs less.
Alternatively, you could use something like Peak Global regular or the lifetime formulation that claims that you'll never have to change the coolant again.
2007 Camry 2.4L 5M
Old 12-08-2011, 02:51 AM   #3 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Toyota Pink is for all aluminum systems, which you do not have. Use Toyota RED.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
Old 12-08-2011, 06:16 AM   #4 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
http://www.bobistheoilguy.com/forums...1747873&page=1
http://www.toyotapart.com/ENGINE_COO...T-PG010-02.pdf
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
The Following User Says Thank You to Stillrunning For This Useful Post:
xpeed (12-08-2011)
Old 12-08-2011, 06:51 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Stick with Toyota Red and 50% distilled water, Valvoline Asian vehicles formula, or flush clean and use Valvoline G-05 if your water pump doesn't use a cheap rubber seal.
Here is the Motor.com article on the Toyota Pink coolant:
http://www.motor.com/article.asp?article_ID=816
"Results of industry standard tests of the new Toyota extended-life coolant now show a substantial weight loss (corrosion), both in a 50-50 mix and in a 33% coolant mixture (solder corrosion is much greater in this more diluted solution). If you have to change a radiator or heater core, use aluminum."
Specifically it's the solder used in copper/brass heat exchanger. Besides the solder the Pink only offers "a small amount" of protection for brass/copper. I guess that's why Toyota still sells both the Red and the Pink coolants. Since Toyota jacked up the price of the Red to nearly $30/gal, an alternative is NAPA's Valvoline Asian Vehicles formula ($11/gal pre-diluted). Looking at the ingredients list it's similar to the Toyota Red, with sodium benzoate as the primary inhibitor (vs the Pink's sebacic acid, or 1/2 of Dexcool which also contains the dreaded 2EHA acid).
Here is another excellent Motor.com article on coolants:
http://www.motor.com/article.asp?article_ID=1655
The Following User Says Thank You to JohnGD For This Useful Post:
fenixus (12-09-2011)
Old 12-10-2011, 01:02 AM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
^excellent articles, bookmarked them. thanks John!
Old 12-10-2011, 02:38 PM   #7 (permalink)
You're welcome. It's these articles and other discussions like in BITOG that I wouldn't recommend coolants like All-Makes. However, there seem to be many who reported the Dealth-cool clone worked fine for them.
Old 12-10-2011, 05:30 PM   #8 (permalink)
抵抗は無駄です
fenixus's Avatar
... so ... I read through both articles and I am scared of how complicated the issue is LOL!
... seems that still the best option is to use Toyota RED LLC concentrate with distilled water. or Zerex Asian Formula premixed (with whatever water it comes, probably tap) with shorter interval ... or that Valvoline Asian formula (same story probably)... or old G-05 with much shorter intervals ...
I wouldn't dare using green (usually as I read, but not any more in some OE applications) Dex-cool (OAT), silicates are a terrible thing ... I've seen gel deposits on my old GM 3.8L on bottom of return tank and even under the the rad cap, it was scary ... but that car had periods of sitting time and that's probably when the silicates got dropped out from it...
Old 12-11-2011, 10:28 PM   #9 (permalink)
View carpetguy00's Photo Gallery
i have had standard green in mine for a year. havent noticed any problems... i do sometimes smell antifreeze after driving for a while... and every couple months have to top off res bottle... which i guess could be a problem......
97 Camry LE 5SFE 135k
94 Corolla 1.6 @ 215K
97 F150 xlt v6 120k
92 Accord 4cyl 127k (totalled 8.4.11 by semi)
carpetguy00 is offline   Reply With Quote
Old 12-11-2011, 11:14 PM   #10 (permalink)
View Nark's Photo Gallery
And you called that no problem?
Nark is offline   Reply With Quote
Old 12-12-2011, 02:44 PM   #11 (permalink)
do i call that i problem? idk turd. u tell me
97 F150 xlt v6 120k
Old 12-12-2011, 03:56 PM   #12 (permalink)
I doubt tap. Probably treated water and QC controlled. You can email them to see what they say.
My choice: "The Super Tech 50/50 Antifreeze/Coolant Pre-Mix is compatible with any antifreeze/coolant used in any vehicle with aluminum and other engine metals.It meets or exceeds ASTM D3306 and D4985 for corrosion protection for cars and light duty trucks while providing freeze-up and boil-over protection."
ASTM D3306: http://www.astm.org/Standards/D3306.htm
ASTM D4985: http://www.astm.org/Standards/D4985.htm
Old 12-12-2011, 04:00 PM   #13 (permalink)
havent noticed any problems... i do sometimes smell antifreeze after driving for a while... and every couple months have to top off res bottle...which i guess could be a problem......
idk turd. u tell me
Touchy, given your own contradiction in the same post.
Old 12-12-2011, 06:21 PM   #14 (permalink)
抵抗は無駄です
fenixus's Avatar
how often do you drain and refill?
I like using red LLC with distilled water, it safely survives 3-5 years without loosing properties...
Old 12-12-2011, 07:04 PM   #15 (permalink)
I've gotten into yearly rad drain and refill. I was trying to test with litmus paper to track acidity but it was hard to get small quantities of proper range litmus and it goes bad quickly. Became to much a PITA so Walmart's green is cheap enough that I can just replace rad quantity to keep properties within spec. I also add ratio amount of Prestone Antifreeze Treatment.
How are you testing, or on faith?
