92 camry makes a light squeal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2011, 10:49 PM   #1 (permalink)
View joewest15's Photo Gallery
my 1992 camry le 2.2 liter engine makes a light squeaking noise since i replaced the water pump and harmonic balance...im thing the belts is dry or loose, but when i use somthing electrical it makes a very loud almost grinding squeal...also when i turn on ac the squeak is moe persistant yet just as light. just trying to pinpoint possible starting points
joewest15 is offline   Reply With Quote
Old 12-09-2011, 12:42 AM   #2 (permalink)
View Pandalizer's Photo Gallery
check how tight the belt is. if it feels loose, adjust the tension pulley. make sure the belt isn't rubbing against the side of any pulleys. never use belt dressing-it'll eventually f*ck up your belt.
_______________________
1998 Toyota Camry | 3.0L 1mz-fe
5900k Headlights | Tockico Struts and Springs
18" Enkei NT03 Racing Series | Metallic Candy Blue Paint
Glow Gauges | Kenwood Deck
x4 Infinity 500 Watt Speakers | 2x 500w Pioneer Subwoofers | N1 Catback
Pandalizer is offline   Reply With Quote
Tags
belt, camry
