2001 Camry Differential - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2011, 11:40 AM   #1 (permalink)
TC01's Avatar
View TC01's Photo Gallery
USA 2001 Camry Differential
I own a 2001 Camry 4 cyl that's going on 150,000. I don't know if this year and model has a differential that can be drained. One place I read said it dosen't, another place said it does with a drain & refill plug. Another place said you refill it where you add the transmission fluid for your transmission. Which is right?
If it does have one that can be drained, where is the drain plug located and is there a filler plug as well. How often should this be drained and filled? Thanks
TC01 is offline   Reply With Quote
Old 12-09-2011, 12:03 PM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Its a seperate chamber. Drain and fill plug are on the differential. Uses regular dex III, not to much of it, well under 2 qts.
Loosen filler and then drain. Its a pain to refill I used one of these http://www.harborfreight.com/automot...gun-95468.html to refill. There are better tools but this ones great for sucking our power steering and brake fluid too.
Also, just refill until it starts dripping out. Its a pretty simple job but it takes some time.
carsrus is offline   Reply With Quote
Old 12-09-2011, 12:20 PM   #3 (permalink)
TC01's Avatar
USA
Thanks Carsrus for the reply. I'm going to asume that since you use a suction tool to empty and fill the differential, there's only one plug. Am I right?
Old 12-09-2011, 01:17 PM   #4 (permalink)
cmryhldr's Avatar
View cmryhldr's Photo Gallery
Go to the FAQ - DIY section at the top of this forum. Scroll down to the transmission section and find the one "Differential fluid change' It has photos and instructions.
Heere is a link to it.
Hope this helps.
DIY : Differental Fluid Change
01Camry 4 cyl
04 Highlander V6
cmryhldr is offline   Reply With Quote
Old 12-09-2011, 01:24 PM   #5 (permalink)
No, there are 2. Loosen and remove the fill plug first. If you drain all the fluid through the drain plug and the fill plug is stuck your SOL.
The suction tool is nice to refill with and it has a pretty good capacity.
Old 12-09-2011, 02:49 PM   #6 (permalink)
TC01's Avatar
USA
Carsrus & Cmryhldr thanks for the help. Cmryhldr, the pictures really helped. I'll get to it this week. Thanks to you both again
Old 12-10-2011, 01:21 PM   #7 (permalink)
TC01's Avatar
USA
I changed the differential fluid today. I'm glad I did, it was black. In order to loosen the filler plug, I had to go down between the engine and firewall. I could'nt get enough leverage on it from under the car and the work space was too cramped where it was located. BUT, got it done . Thanks for the help guys, I appreciate it.
Old 12-10-2011, 02:04 PM   #8 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
+1 that's the way I'd recommend, and a funnel and PVC tube to fill from top too. But it also depends on if people have PopEye arms.
