transmission rev high while driving - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2011, 11:47 PM   #1 (permalink)
View bjsharp85's Photo Gallery
So dont know much about this cause i havent owned an auto tran before, but for some reason when im driving the trans feels like it is slipping and will rev up until i let off the gas and drop into 2nd. once i put it in 2nd i can put it back in drive and its fine. any ideas?
bjsharp85 is offline   Reply With Quote
Old 12-10-2011, 07:33 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
First check your trans fluid level. Problem could be delayed or sticking shift solenoid, low pressure, old/dirty fluid. When was the last time fluid was changed?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 12-10-2011, 02:15 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
+1 when was the ATF last serviced and pan dropped/cleaned?
Old 12-10-2011, 05:02 PM   #4 (permalink)
i just bought it so im not for sure. it drove fine the first few weeks and then just started doing this. i have an appointment on monday to have the transmission diagonost to see what is going on with it.
Old 12-10-2011, 05:04 PM   #5 (permalink)
If trans diagnose is by national chain be careful, very careful. Usually you can try cheap easy stuff first, like changing fluid.
Old 12-10-2011, 05:38 PM   #6 (permalink)
yeah the diagnostic is free. im just wanting them to figure out what it is so i can fix it
Old 12-10-2011, 08:50 PM   #7 (permalink)
Don't be surprised if they say you need a new transmission. From what I've seen that's about their solution to every trans problem.
