yeah that works.
When you persuade in the new bearing make sure to hammer on the outer race only and using the
old outer race to drive it. And when installing the hub make sure the inner race is supported from the other end.
Borrow a 250 lb/ft torque wrench and socket from Autozone's free loaner program (with refundable deposit) and torque the axle nut to spec - this will help set the correct bearing preload and make it last. As you may have noticed the halves of the inner race are free floating, so the axle nut torque is very important for the longevity of the wheel bearing.
