how to put Gen 5 wheels on a Gen4? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-10-2011, 10:00 PM   #1 (permalink)
View 305 classic's Photo Gallery
Question how to put Gen 5 wheels on a Gen4?
I have an 01 camry 4cyl with drum brakes in the rear if that even matters but i'm trying to fit rims off of a 2005 solar and the issue i'm running into is the tire rubs on the shock tower and with a 3/8" wheel space the tire rubs on the fender a little bit. has anyone succesfully ran thees rims on a 4 camry?
heres a pic
305 classic is offline   Reply With Quote
Old 12-10-2011, 10:06 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
what size are those rims and tires?
Old 12-10-2011, 10:18 PM   #3 (permalink)
215/55-17 are what i'm using rite now, however i'm having 215/50-17 instaled on monday, I just don't think its going to make much of a difference other than correcting the spedo because of the diamiter and I read FAQ on tire size stuff but that didn't really help me much because I don't have any idea what the backspacing is or anything
Old 12-10-2011, 10:27 PM   #4 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
Going from 212/55-17 to 215/50-17 will knock off nearly an inch off the entire diameter of the tire and very close to the OEM diameter. Most offset are between 38-44 for Camry. I would try to run it without the spacer after the new tires.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 12-11-2011, 12:38 AM   #5 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $589157
iTrader Score: 7 reviews
View xpeed's Photo Gallery
You should be able to run them without any problems if you have the correct tires. I have 18s on mine with a 245/45 tires I think. Don't know if it's 225, but anyways. It barely passes by 5mm. Your tires are too thick so in between 215/50-225/45 is enough to clear it for you.
Basic info on tires:
the triple digit number you find on tires, Ex. 225/xx 215/xx refers to the width of the tire.
The double digit after the first set, Ex. 212/55, 225/45 refers to the thickness of the tire wall (Sidewall). The spacing between the outer rim of your wheel and the outer surface of your tire. The higher the number, the thicker is, lower, the thinner it is. Hope that clarifies it a bit for you.
Here's a link that goes in depth on tire sizes, the meaning behind the numbers, letters, and dimensions.
http://www.tirerack.com/tires/tirete....jsp?techid=46
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 12-11-2011, 08:32 AM   #6 (permalink)
yeah I understand the specs of the tire digits, I just wasnt sure if when I put these new tires on if that was going to help prevent it from rubbing because it's rubbing on the side so reguardless of height the width is the main issue. I forgot to mention that part because the stocks were a 205 I beleive and the new are 215 which isnt a huge jump but i'll see what happens tomarow with the tires
Old 12-11-2011, 11:47 AM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
so 50 is max that fits with 17s?
and 45 is max for 18s?
Old 12-11-2011, 11:48 AM   #8 (permalink)
TN の がしょう
xpeed's Avatar
Okay, I thought you were talking about the upper part of the tire rubbing on your struts. If it's the inner sidewall rubbing your struts, the cheapest way is to get some spacers. 5mm should be enough to clear it. As for rubbing the fenders, going from 55 to 50 should help.
What is the offset for the solara wheels? My 18s offset is +38 and barely clears by 5mm.
Old 12-11-2011, 11:51 AM   #9 (permalink)
TN の がしょう
xpeed's Avatar
Well, you can say that if you have it lowered and don't want to roll you fenders with minor modifications to your wheel well, then yes. 45 is the max if you're lowered, 50 if not if you're rolling on 18s. 17s, I think you can go up to 55 max on factory height.
The Following User Says Thank You to xpeed For This Useful Post:
fenixus (12-11-2011)
Old 12-11-2011, 12:46 PM   #10 (permalink)
抵抗は無駄です
fenixus's Avatar
right, thanks, the difference between stock and lowered height makes it more clear now to me why people prefer certain aspects and thicknesses of tires
Old 12-18-2011, 08:09 PM   #11 (permalink)
the 215/50-17 seem to do the trick however I still had to use the wheel spacer but no more scrapes. thanks for everyones help
