Torque spec for the rear caliper bolts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2011, 03:02 PM   #1 (permalink)
View cccxyz's Photo Gallery
A bit urgent.
Does anyone know the torque value for the rear caliper bolts for Camry Wagon? It is a 12mm size. There is only one for each caliper, right?
Can anyone also verify if the torque value for the front caliper bolts for Camry Wagon is 25 ft-lb?
Thanks!
cccxyz is offline   Reply With Quote
Old 12-11-2011, 03:12 PM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Do you mean the two bolts (per caliper) that mount the caliper to the suspension? If so spec calls for 14 ft/lbs, although I've never used a torque wrench on the calipers, just gotten to know what feels right. Helps if you use anti-seize to make next tear down easier.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 12-11-2011, 03:34 PM   #3 (permalink)
The bolts mount the caliper to the suspension is torque plate. I remember it is something 75 ft-lb.
I meant the installation bolt for the brake pads. 14 ft-lbs is out of the range of my torque wrench ... Wondering if I should buy another torque wrench now...
Old 12-11-2011, 03:56 PM   #4 (permalink)
Yes, torque plate - front = 79 ft/lbs, rear = 34 ft/lbs
You mean slide pin bolt. 20 ft/lbs
just tighten it good, you'll be fine, it's a brake after all.
** Edit: After thinking about torque spec for torque plate I thought it seemed low. Haynes says 34 ft/lbs. Re-checked FSM and found proper torque at rear page of rear brake - FSM is not too clear on this.
Old 12-11-2011, 04:38 PM   #5 (permalink)
Thanks.
Old 12-11-2011, 05:37 PM   #6 (permalink)
See Edit in above post on torque of torque plate bolts.
Old 12-11-2011, 05:44 PM   #7 (permalink)
Got you. Thanks!
Old 12-11-2011, 08:36 PM   #8 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
rear caliper slide pin bolts torque is 14ft-lbs.
rear caliper bracket mounting bolts torque is 34ft-lbs
Old 12-12-2011, 06:01 AM   #9 (permalink)
FSM talks about 1 caliper installation bolt (14 ft/lbs) and 1 main pin installation bolt (20 ft/lbs). The main pin appears to be the one on top side.
Old 12-12-2011, 09:15 AM   #10 (permalink)
抵抗は無駄です
fenixus's Avatar
sorry, it must be a different rear caliper setup than I have. you are probably right.
