Removal of 1999 Toyota Camry LE OEM Spoiler? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2011, 07:31 PM   #1 (permalink)
View anuhn's Photo Gallery
4th Generation Removal of 1999 Toyota Camry LE OEM Spoiler?
I recently sound deadened the trunk of my car and I noticed a majority of the rattle is coming from the spoiler's brake lights/trunk lid brake lights.
I unbolted the bolts that were attached to the spoiler, but the spoiler wont budge.
How do I get this thing off?!!
I need to take it off so I can get rid of that nasty rattle!! AGHHHH
anuhn is offline   Reply With Quote
Old 12-11-2011, 08:12 PM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Its uses adhesive foam, gently pry it up by sliding a knife underneath.
You gonna have a good amount of holes left over. There are the 2 for the bolts but there are also 2 much larger one where the spoiler snaps in. It might be easier to just let it rattle.
carsrus is offline   Reply With Quote
Old 12-11-2011, 08:52 PM   #3 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
Instead of a knife, you can cut the foam tape with fishing line or a strong string. I have a friend who removed his rear spoiler from his ES300. He just covered the holes with plastic plugs from Home Depot.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 12-12-2011, 03:14 AM   #4 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Much better alternative to cutting the double sided tape. Don't have to worry about the excess tape that sticks. A heat gun or hair dryer will make it easier as it soften the glue.
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
Old 12-12-2011, 10:11 AM   #5 (permalink)
I was pretty sure there was some type of adhesive on the spoiler, but I wasn't sure.
The only bolts I saw were two bolts that were visible behind the trunk lid. Other than that, I didn't really see anything else that was attached to it.
And thanks a lot for the replies you guys. I've been a frequent TN viewer just lurking around and never really came about to making an account, and now, I finally did.
[edit]
And I forgot, I plan on keeping the spoiler on, but I wanted to take it off to find a way to reduce the rattling from the spoiler brake light. Does anyone have an idea or has already reduced the rattling of their OEM spoiler? I planned on finding some spray foam to shove in there, but I wasn't sure if the OEM spoiler has holes I am able to spray into.
All this for the sake of bass. fml
