How to remove the passenger side panel to access blower motor? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2011, 10:39 PM   #1 (permalink)
View wc1972's Photo Gallery
Hi All,
My 99 Camry stopped blowing air at lower speed years ago.
From my research, I figured out that it is due to a broken blower motor resistor.
I bought a OEM resistor from Amazon, but here is the problem:
I cannot remove the panels under the glove box to access the resistor.
I have seen multiple posts showing how to change the resistor, but none of them showed how to remove the panels first.
Is it so simple that people don't bother to mention it?
Thanks an advance.
wc1972 is offline   Reply With Quote
Old 12-12-2011, 12:09 AM   #2 (permalink)
Gameroom cash: $326045
View adalex's Photo Gallery
hey i assume you mean getting the glove box out? if so when i get home tomorrow if i get a few minutes ill take a video of me taking it off (also have a 99 camry le)
adalex is offline   Reply With Quote
Old 12-12-2011, 04:34 AM   #3 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
They're a bit fiddly. Try and find where the clips are and give a nice firm pull on an angle(towards you and downward). IIRC, the clips are around the corners. Once you have the back off(closest to the engine) it gets easier. Don't force anything though, if it feels like it's going to break; it probably will.
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
Old 12-15-2011, 08:17 PM   #4 (permalink)
Thanks to Adalex and Jimnist.
I will try to remove the panel directly under the glove when It is a bit warmer.
Tags
resistor access
