I've replaced mine, and it's pretty straightforward.
2 bolts on the front.
1 at the rear.
2 nuts & 1 bolt holding it to the ball joint at the steering knuckle (might be 2 bolts & 1 nut; not sure).
I replaced the bushings in mine instead of buying the assembly. In hindsight, I wouldn't do that again. Not worth the hassle. Getting the front bushing out was a royal PITA, even using my buddy's 20 ton hydraulic press.
