New Starter Motor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-12-2011, 01:34 PM   #1 (permalink)
View coffee-3000's Photo Gallery
3rd Generation New Starter Motor
My starter motor is making a horrible screeching sound when the outside temperature is really cold. I think I need a new starter motor. Do you usually replace the starter motor and the solenoid togther as a unit or just the starter motor by itself ?
The Hyanes manual says to remove the two small screws that attach the gear housing to the engine block. But should I only remove the two long screws that hold the starter motor ? I've attached a photo for reference. Thanks again.
1996 V6 Camry 150K
coffee-3000 is offline   Reply With Quote
Old 12-12-2011, 09:02 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863310
View BamZipPow's Photo Gallery
The 2 long bolts are fer keeping the electric motor attached to the gear reduction transmission...that wouldn't be a good idea to remove. You'll never git it back together with the rest of it bolted to the engine.
Yer best bet is to remove the 2 short bolts that hold the starter to the engine block. Make sure you remove the ground at the battery so you don't end up welding yer wrench/ratchet to the starter if you touch the positive cable.
It sounds like yer starter isn't engaging the flywheel all the way when yer starting the engine. You might want to inspect the flywheel carefully fer damage...
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 12-12-2011, 09:33 PM   #3 (permalink)
Thanks for the reply. But are you saying that the whole unit ( motor, solenoid, and gear reduction housing ) will all come out when I remove the 2 short bolts ? And then I should unbolt the motor from the unit and swap in a new one ?
Or do you normally purchase the whole unit when you buy a new starter ?
Sorry for being so dense.
1996 V6 Camry 150K
Old 12-12-2011, 09:56 PM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
Yep, when you buy a "starter" you get the whole enchilada.
BMR is offline   Reply With Quote
The Following User Says Thank You to BMR For This Useful Post:
coffee-3000 (12-14-2011)
Old 12-13-2011, 12:30 AM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Denso reman is about $122 plus core and shipping. But maybe clean and lube the gear portion first and inspect the solenoid contact areas as well to help engage the gears.
See also:
http://www.rav4world.com/forums/88-4...ir-w-pics.html
The Following User Says Thank You to JohnGD For This Useful Post:
