2001 Camry LE Fast Idle on Start Up. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-12-2011, 05:49 PM   #1 (permalink)
Gameroom cash: $872000
View zb420's Photo Gallery
Mom's 2001 4 cyl. is idling fast at start up.
She says she can drive up our block without using the gas pedal.
It's a residential street so I can't see it doing that many mph. or she would brake.
What could it be?
The car has 39,000 miles on it and has been kept up.... (not as good as I keep up mine but I'm OCD)
1993 Camry LE 2.2l
Original owner
112k mi.
zb420 is offline   Reply With Quote
Old 12-12-2011, 07:21 PM   #2 (permalink)
Brilliantly Stock
Dlundgren97's Avatar
View Dlundgren97's Photo Gallery
Mine idles up to about 2k rpm and stays there (in park) for quite a bit especially sinces its been at or below freezing in the morning. If your mother is just putting it drive right after start up then even in gear the idle will still be at about 1200rpm. And an idle at 1200 will most definitly move you faster down the road than a 750rpm warm idle.
High idle is normal on a cold engine in order to heat up the o2's to operating temp.
And on the other hand, if your mothers car is idling at like 2000rpm in gear going down the street then yes you would most definatly have a problem...
Dlundgren97 is offline   Reply With Quote
Old 12-12-2011, 07:37 PM   #3 (permalink)
Tune up?
1993 Camry LE 2.2l
Original owner
112k mi.
Old 12-13-2011, 01:45 AM   #4 (permalink)
View Nark's Photo Gallery
You can remove the air duct and partially duck tape IAC inlet hole. Start it up in the morning and if the rpm normal then you need new IAC which cost about $200-300.
Nark is offline   Reply With Quote
Old 12-13-2011, 03:47 AM   #5 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
^ thats a good little trick.
all of my camrys have done the same (3), what RPM is is sitting at and for how long? When does it drop down? Mine would easily drive itself and even have the power to make it to second gear but they were V6s.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 12-13-2011, 02:08 PM   #6 (permalink)
Thanks everyone... my mechanic will stop by her house and check it out later.
1993 Camry LE 2.2l
Original owner
112k mi.
