Install a Deck ?
I have a 2001 camry xle . It has the wood grain finish , i would like to change the stock deck that is in it right now which is a double din to a single din deck, but i would like it to fit just like the stock deck i know that i will have to put the pocket underneath to fil in the space.The stock decks corners are at at a 90 degree angle where as a lot of the decks i see have that sort of rounded finish on them before you put the face plate on. Has anyone installed an aftermarket deck without using the face plate that comes with it, and instead used the woodgrain plate finish of the camry . Can i get some feed back -on the look and how it fit or anything i might need to know . Thanks
