RS3000 - doors won't lock - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-13-2011, 09:44 PM   #1 (permalink)
View jrrhodes's Photo Gallery
I hit the remote and the lights flash and it chirps, but the doors don't lock. Tried to erase all remote control codes, but when I pressed the ECU's for 3 seconds, the Status Monitor LED doesn't turn on. Without being able to reset it, I can't reprogram it to lock the doors.
Any ideas?
jrrhodes is offline   Reply With Quote
Old 12-14-2011, 07:24 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863310
View BamZipPow's Photo Gallery
Does the power locks work in the first place? Check fuses/relays first.
Are you sure all the wiring from the RS3000 ECU is intact? You'll probably need to trace it from there to where it interfaces into the power lock wiring loom.
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 12-15-2011, 05:19 AM   #3 (permalink)
The power locks work when using the switch on the arm rest. The ECU was unhooked to verify that it wasn't causing another problem. The other problem was fixed, but didn't hook the ECU back up until a month later.
If I use the key to unlock after hitting the key fob once, it sets off the panic alarm.
Looked at the functions in the manual and I can't set any of them because 1 step is always to wait until the security light turns red, which doesn't happen. If I do the lock sequence with the key fob, the lights flash and then the red light does start flashing like it is set.
Old 12-15-2011, 10:15 PM   #4 (permalink)
BamZipPow's Avatar
Maybe the alarm ECU is hosed? Dunno...
