Originally Posted by DarkSideMoon
4. I've heard with the 3vz-fe that you can advance the timing (as long as you put in 93 octane) to get some more horsepower out of it. I've also heard you can adjust the fuel/air mixture as well. Could someone point me in the right direction for those?
DarkSide - here's a link to the AFM cog adjustment.
As for the timing, stock is 10 degrees BTDC, and you can go to 15 or 17 (depending on which thread you run across) without using premium.
FWIW, I've got my AFM cog set at 5 clicks leaner, and my timing's at 15 degrees. Has been for 3 years now, and I haven't had any issues running regular gas.
Originally Posted by Nark
Change timing!!! how do you do that w/o change out the chip?
The 3VZ-FE motor has a distributor. Timing is set the old school way with a timing light. Need to install a jumper across TE1 & E1 before adjusting.
