defrost wont work 1998 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2011, 10:30 AM   #1 (permalink)
View Randall1989's Photo Gallery
Hi, I have a 1998 Camry. The AC/heat will only blow out of the main vents, I can change the blow setting to main front vents, front and feet vents, feet only vents, defrost, etc......but it only blows out of the main front vents no matter what setting i put it on.
What could be the problem?
I was thinking a vacuum line might be disconnected...but i looked under the hood and didn't see any breaks or disconnections.
Randall1989 is offline   Reply With Quote
Old 12-17-2011, 07:55 PM   #2 (permalink)
Any ideas guys?
Old 12-17-2011, 08:31 PM   #3 (permalink)
View jake679's Photo Gallery
im pretty sure the diffrent vents are changed by an electric servomotor there shouldnt be any vacuum involved, maybe your defrost vents are being blocked up? maybe the servomotor is not working you can look underneath the dash on the driverside if you change vents while looking you should see the motor turning
jake679 is offline   Reply With Quote
Old 12-18-2011, 05:45 AM   #4 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Originally Posted by Randall1989 View Post
Any ideas guys?
Faulty mode selection switch or connection. You'll have to remove it and diagnose.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 12-25-2011, 08:45 PM   #5 (permalink)
Ok thanks guys, im going to try to look at it next week when i have some time off
Old 02-21-2012, 03:36 AM   #6 (permalink)
View dwz07's Photo Gallery
Hey did you ever solve this problem? I just bought a 98 as well and have the same problem (among others ) but would like to knock this one out first. I found a part number for that servomotor which was 87106-06060 is this the correct number?
dwz07 is offline   Reply With Quote
Old 02-22-2012, 08:40 AM   #7 (permalink)
im pretty sure it is my servo motor too...but i havent been able to locate where it is...i think you have to take out the glove box, but i just havent been ready to tear apart the dash to find it. Ill let you know when/if i do it, and please let me know if you do it first and how it went.
Old 02-22-2012, 04:45 PM   #8 (permalink)
take a flashlight and look underneath your driver's side foot-well. look up and to the right (towards the center console) and you should see a white plate. this is where that servomotor lives. once that white plate is removed (there is a white locking tab in the center which can be released with a screwdriver) you should be able to remove the servomotor (3 mounting screws total)
what i did today was just remove that white plate and manually move the levers so it directed the air to the defroster rather than the face (this manual adjustment will work just fine for me!)
http://www.justanswer.com/toyota/5zu...-98-camry.html
check out that link for a good picture and instructions. hope this helps! let me know if you need more help
The Following User Says Thank You to dwz07 For This Useful Post:
Randall1989 (02-22-2012)
Old 02-25-2012, 04:04 PM   #9 (permalink)
View masi's Photo Gallery
I Had the exact same problem.I went to the junk yard and pulled out the servomotor from a used camry and replaced it and everything was fine.Most likely it will be the servomotor.Goodluck
masi is offline   Reply With Quote
