95 Camy 1MZ-FE hesitation at WOT - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2011, 11:26 AM   #1 (permalink)
View thsettle's Photo Gallery
I have a 95 Camry 1MZ-FE -- once the engine is warm (up to operational temp) if I hit the gas and get the RPM's past 4,000 -- there is a big hesitation /like a misfire. The car surges/ hesitates rapidly (like machine gun)-- it seems like it wants to go but does not. If I get off the gas and go back to under 4,000 RPM car runs fine. Idles fine -- plenty of power -- only a problem under load past 4,000 rpm. No codes being thrown or pending. Plugs changed 32,000 ago -- gas mileage 26 MPG on highway -- at 80 MPH
This would be fine but if you have to pass another car -- is a big problem.
Any ideas on how to find the problem -- where to start.
thsettle is offline   Reply With Quote
Old 12-15-2011, 12:46 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
First guess is air filter needs changing. To test, try taking the filter out and see if that fixes it.
Second guess is fuel pump is marginal.
BMR is offline   Reply With Quote
Old 12-15-2011, 01:55 PM   #3 (permalink)
Thanks for the fast reply
Thanks for the fast reply -- I will check both.
Found one bit of info -- The 94-96 1MZs use a vacuum modulated EGR system that cuts off at 4100-4200 RPM. I believe the EGR VSV vents to atmosphere during that time to bypass the EGR system? Not sure if this is correct?
