Water in rear passenger footwell - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2011, 05:33 PM   #1 (permalink)
View eemann23's Photo Gallery
USA Water in rear passenger footwell
I have water mysteriously appearing on the floor in front of the rear passenger seat. It is not coming in from the roof or window. I hear a swoosh sound of water coming from under the car as I drive. Were is the water coming from and how can I drain and stop it's entry onto the floor in front of the rear passenger seat?
eemann23 is offline   Reply With Quote
Old 12-15-2011, 10:28 PM   #2 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $589157
iTrader Score: 7 reviews
View xpeed's Photo Gallery
Have you checked your door and try swinging it side by side to see if there's water in there? My grandma's Avalon had a similar problem and found out it was inside the door. Quite weird, but I drained it first by using Shamwow, but there was too much so I just drilled a hole at the bottom part of the door and it all came out.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 12-15-2011, 10:56 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
There are drain holes on the bottom of the doors inner edges. Maybe they're plugged up.
Also check the truck spare tire area and the fender pockets under the carpet.
Tags
leak into car, water in car
