Originally Posted by
bosshog87
So I had the same problem after cleaning the throttle body with carbuetor cleaner. I did kinda spray a lot inside the throttle body thoigh, literally took a day and a half of putzing with it and I bought new plugs to get it started. I cleaned the throttle initially because I had a "sticky" pedal on takeoffs, that problem is fixed but now it feels as tho the idle is hiccuping, it never actually dies but more jumps from a steady 850ish to almost a 550rpm.
Any ideas?
I put sum fuel injector cleaner in, no help, no codes either...
How can I test my IAC? Are there any type of setting procedures for it because I did unplug it and unscrewed the two bolts that hold it in place during the no start condition just to look at it, but then i put it right back....could that have done something?
And i did use an autozone brand carb cleaner...
Any help would be appreciated
2000 toyota camry 4cylinder
Nebel777@yahoo.com
Ahhh!, let just hope you didn't use carb cleaner on TPS. You know it'll damage TPS right? Carb cleaner has petroleum lubricant that will bind to electronic contact and render it useless.
I cut/paste the above from another forum in hoping to show this is what will happen when you try to save $2 buck.
