Need help with 3rd gen camry Heater issues!
Hey guys just wondering if anyones had any issues like this.. The heater in my camry is blowing out maybe 65 or 70 degrees with the temp gauge at full operating temp, i have replaced the radiator, the higher quality water pump, and higher quality thermostat, and the rad cap. I have flushed the system and im pretty sure most if not all the air is out. I have found that if i dont run the heater for a few minutes then run it it will be hot for about 20 seconds, then its gone..its getting pretty cold here in the midwest it would be nice to have some heat lol. any ideas would be appreciated! im wondering if it is the "blend door" but when i move it from hot to cold and back it sounds like a thud when it shuts so it sounds like its shutting both ways, Also the two pipes comming out of the heater core are hot
on a side note anyone have problems with blowing the starter fuse? i blow one about every other time i try to start the car
